Ricoh SG 3110DN Error SC (28212)
Lord_Matty
Re: Ricoh SG 3110DN Error SC (28212)
Post by Lord_Matty »
I have just had the following message along with a red light appear on my printer.
SC (28212)
Power Off On
Call service if Error reoccurs
I have tried turning power off and on as instructed but still no luck.
Any ideas?
TjCanvas
Post by TjCanvas »
I had this problem last week. I contacted BMS (where I got the printer from) Who advised me to change all the inks and preform a carriage reset. They sent me instructions on how to do this.
Hope it helps
TjCanvas
Post by TjCanvas »
Please be aware it does drain alot of ink when you do the reset.
Lord_Matty
Thanks, I will take a look.
I might give BMS a call, I purchased it from them a few months ago and only installed new inks last week and I don't fancy wasting expensive ink! :)
TjCanvas
Post by TjCanvas »
If you only got it a few months ago they will sort everything out for you. I received First Class service from them as always.
TjCanvas;69402 wrote:I had this problem last week. I contacted BMS (where I got the printer from) Who advised me to change all the inks and preform a carriage reset. They sent me instructions on how to do this but to save me typing it all just done a search and found a video which explains it all. http://www.youtube.com/watch?v=l21ewmTxDJE
Hope it helps
DO NOT DO THIS. The reset process must ONLY be done with a brand new set of cartridges with authorisation from your supplier in conjunction with Sawgrass.
TjCanvas
Post by TjCanvas »
That's why I put you advised me to change all the inks, I was just trying explain the process. Edited the post didn't mean to get into trouble,
TjCanvas;69411 wrote:That's why I put you advised me to change all the inks, I was just trying explain the process. Edited the post didn't mean to get into trouble,
Not suggesting you'd get into trouble :). Just don't want anyone doing this, wasting a huge amount of ink and then contacting their supplier as the first contact should be with the supplier and the reset should only be done with a brand new set of cartridges.
TjCanvas
Post by TjCanvas »
Yeah I was gutted watching a new set of cartridges drain but it made the printer work until today :( do you do the waste ink cartridge as its filled up quite abit?
TjCanvas;69416 wrote:Yeah I was gutted watching a new set of cartridges drain but it made the printer work until today :( do you do the waste ink cartridge as its filled up quite abit?
Cartridges might have drained but I presume you had contacted us as your supplier if it was the same error code and we supplied you with a set FOC so there was no cost to you. We do supply waste tanks as well, all online.
