Ricoh SG 3110DN Error SC (28212)
Lord_Matty
Re: Ricoh SG 3110DN Error SC (28212)
I have just had the following message along with a red light appear on my printer.
SC (28212)
Power Off On
Call service if Error reoccurs
I have tried turning power off and on as instructed but still no luck.
Any ideas?
SC (28212)
Power Off On
Any ideas?
I had this problem last week. I contacted BMS (where I got the printer from) Who advised me to change all the inks and preform a carriage reset. They sent me instructions on how to do this.
Hope it helps
Hope it helps
Please be aware it does drain alot of ink when you do the reset.
Lord_Matty
Thanks, I will take a look.
I might give BMS a call, I purchased it from them a few months ago and only installed new inks last week and I don't fancy wasting expensive ink!
If you only got it a few months ago they will sort everything out for you. I received First Class service from them as always.
DO NOT DO THIS. The reset process must ONLY be done with a brand new set of cartridges with authorisation from your supplier in conjunction with Sawgrass.TjCanvas;69402 wrote:I had this problem last week. I contacted BMS (where I got the printer from) Who advised me to change all the inks and preform a carriage reset. They sent me instructions on how to do this but to save me typing it all just done a search and found a video which explains it all. http://www.youtube.com/watch?v=l21ewmTxDJE
Hope it helps
That's why I put you advised me to change all the inks, I was just trying explain the process. Edited the post didn't mean to get into trouble,
Not suggesting you'd get into troubleTjCanvas;69411 wrote:That's why I put you advised me to change all the inks, I was just trying explain the process. Edited the post didn't mean to get into trouble,
Yeah I was gutted watching a new set of cartridges drain but it made the printer work until today
do you do the waste ink cartridge as its filled up quite abit?
Cartridges might have drained but I presume you had contacted us as your supplier if it was the same error code and we supplied you with a set FOC so there was no cost to you. We do supply waste tanks as well, all online.TjCanvas;69416 wrote:Yeah I was gutted watching a new set of cartridges drain but it made the printer work until todaydo you do the waste ink cartridge as its filled up quite abit?
