ricoh sg3110dn sublimation printer
valentine rhodes
Re: ricoh sg3110dn sublimation printer
Have just got myself an early christmas present,a ricoh sg3110dn, when i have finished using it,do i turn it off,or leave it turned on, till i next use it?
Normally leave on, but if you're going away for a month then switch it off!valentine rhodes;61562 wrote:Have just got myself an early christmas present,a ricoh sg3110dn, when i have finished using it,do i turn it off,or leave it turned on, till i next use it?
That's normalviccar;61599 wrote:my screen goes off altogether just the blue light stays on
If you leave it on (or on standby) the printer will periodically perform a head clean to make sure that is doesn't get clogged up. So, it is recommended not to turn it off fully - this will mean that you're using ink even when not printing, but at least your printer should be able to print for you next time you need it.
