ricoh sg3110dn sublimation printer
valentine rhodes
Re: ricoh sg3110dn sublimation printer
Post by valentine rhodes »
Have just got myself an early christmas present,a ricoh sg3110dn, when i have finished using it,do i turn it off,or leave it turned on, till i next use it?
viccar
Post by viccar »
It recommends you leave it on standby.
valentine rhodes;61562 wrote:Have just got myself an early christmas present,a ricoh sg3110dn, when i have finished using it,do i turn it off,or leave it turned on, till i next use it?
Normally leave on, but if you're going away for a month then switch it off!
frazzle
Post by frazzle »
How do you leave it on Stand by
gorgall2
Post by gorgall2 »
Just leave it and it will do it itself.
gorgall2
Post by gorgall2 »
It will say energy saver on the screen.
frazzle
Post by frazzle »
Thanks gorgall2
viccar
Post by viccar »
my screen goes off altogether just the blue light stays on
viccar;61599 wrote:my screen goes off altogether just the blue light stays on
That's normal :)
If you leave it on (or on standby) the printer will periodically perform a head clean to make sure that is doesn't get clogged up. So, it is recommended not to turn it off fully - this will mean that you're using ink even when not printing, but at least your printer should be able to print for you next time you need it.
