Profile setting in P/S ?
scotty44
Re: Profile setting in P/S ?
Post by scotty44 »
Just a quick question for anyone using a Ricoh & photoshop!
Should the profile be set to Picture 1 (turned off) or 2 ?
vB_ID:3367
vB_ID:3367
vB_ID:3366
vB_ID:3366
both are wrong!
Use photoshop manages colours with the ICC profile when printing with the Ricoh driver (make sure any colour management or enhancements are then turned off in the print driver options)
or
Use printer manages colours when printing to power driver
document profile should be Adobe 1998
scotty44
Post by scotty44 »
:eek: Ok I'll try again......
Would these look better, if I get what you say mate this should look right :rolleyes:
Bugger it's added the other 2 files too, new ones are "printer 1" and "printer 2"
vB_ID:3369
vB_ID:3369
printer 1.jpg (95.12 KiB) Viewed 285 times
vB_ID:3368
vB_ID:3368
printer 2.jpg (89.04 KiB) Viewed 285 times
I'd direct you to the Sawgrass setup page but who knows what's going on with their site right now!!!
You can still get tech support from SG site but need to register to log in.
http://www.techsupport.sawgrassink.com/v.php?pg=3964
Which version of PS are you using? This is the setup for CS-CS5....
https://www.dropbox.com/s/bxr40cbn384gq ... t.pdf?dl=0
scotty44
Post by scotty44 »
Justin, Iv'e been on there and put the V4 in but comes up with an error so I fail on step 2 from this PDF -
http://sawgrassink.indigofiles.com/prod ... Preset.pdf
I have no Sawgrass option in the color settings in that box on step 2 :confused:
Are you not using Powerdriver?
scotty44
Post by scotty44 »
Yes mate just not the V4 on the link you posted above (not sure what version it is)
scotty44
Post by scotty44 »
I would mate but like I said I get an error half way through installing V4 (system error)
Just checked and I'm using Powerdriver 3.6.4.2719
