Profile setting in P/S ?
Re: Profile setting in P/S ?
Just a quick question for anyone using a Ricoh & photoshop!
Should the profile be set to Picture 1 (turned off) or 2 ?
- vB_ID:3367
- power2.jpg (90.61 KiB) Viewed 277 times
- vB_ID:3366
- power1.jpg (87.93 KiB) Viewed 277 times
both are wrong!
Use photoshop manages colours with the ICC profile when printing with the Ricoh driver (make sure any colour management or enhancements are then turned off in the print driver options)
or
Use printer manages colours when printing to power driver
document profile should be Adobe 1998
or
Would these look better, if I get what you say mate this should look right :rolleyes:
Bugger it's added the other 2 files too, new ones are "printer 1" and "printer 2"
- vB_ID:3369
- printer 1.jpg (95.12 KiB) Viewed 277 times
- vB_ID:3368
- printer 2.jpg (89.04 KiB) Viewed 277 times
I'd direct you to the Sawgrass setup page but who knows what's going on with their site right now!!!
You can still get tech support from SG site but need to register to log in.
http://www.techsupport.sawgrassink.com/v.php?pg=3964
Which version of PS are you using? This is the setup for CS-CS5....
https://www.dropbox.com/s/bxr40cbn384gq ... t.pdf?dl=0
Justin, Iv'e been on there and put the V4 in but comes up with an error so I fail on step 2 from this PDF -
http://sawgrassink.indigofiles.com/prod ... Preset.pdf
I have no Sawgrass option in the color settings in that box on step 2
Yes mate just not the V4 on the link you posted above (not sure what version it is)
I would mate but like I said I get an error half way through installing V4 (system error)
Just checked and I'm using Powerdriver 3.6.4.2719
