I purchased a Ricoh 3110D - I had a go at making some coasters for the first time last night, lots of tips and information on here which really helped.
The problem is:-
1. This is the original picture, notice the brown part of the dog is a chestnut colour. When printed on a normal printer it is almost perfect. When I print onto the sublimation paper, it is slightly orange. Once the image is processed onto the coaster it turns into a bright orange. I have just looked at the mugs I produced earlier in the week and they are also orange. I set the temperature for 200, initially 60 seconds but the image looked scuffed, so I increased to 70 seconds, everything looked perfect except the chestnut colour is orange.
This is the originial.
[ATTACH=CONFIG]1487[/ATTACH]
This is the print on sublimation paper you can see how the colour has changed slightly to orange! I am concerned the colour has gone wrong at this stage.
[ATTACH=CONFIG]1488[/ATTACH]
This is a selction of four I produced, the ears have turned orange.
[ATTACH=CONFIG]1489[/ATTACH]
Colour Problems Again
Re: Colour Problems Again
- vB_ID:1489
- Sublimation Coasters example.jpg (75.79 KiB) Viewed 14 times
- vB_ID:1488
- Optimized-Printed_on_Ricoh_paper 2.jpg (22.88 KiB) Viewed 14 times
- vB_ID:1487
- Optimized-Bohemian_Cavs_Blenheim.jpg (86.32 KiB) Viewed 14 times
[ATTACH=CONFIG]1490[/ATTACH]
Have you changed the sublimation product to unisub or whatever the coasters are in the powerdriver?
The top right hand one looks like moisture, did you pre press them?
- vB_ID:1490
- Untitled.jpg (59.74 KiB) Viewed 14 times
Hi
I have checked through the printer setting and I don't have the page of setting you have shown! Is there some software I should have installed when I got the printer.
Thank you for your reply.
[ATTACH=CONFIG]1492[/ATTACH]That is the powerdriver.
When you go to print do you see on the list of printers power driver
1 choose printer
2 click on here show the other screen
1 choose printer
- vB_ID:1492
- Untitled.jpg (90.39 KiB) Viewed 14 times
You'll need to download and installTania;64034 wrote:Hi
PowerDriver:
http://sawgrasseurope.com/technical-sup ... c-profiles
I have done the download and it works, thank you. What do I select for coasters as that is not on the list. Sorry to keep asking basic questions.bms;64039 wrote:You'll need to download and install
PowerDriver:
Just leave it at he the default settings.Tania;64041 wrote:I have done the download and it works, thank you. What do I select for coasters as that is not on the list. Sorry to keep asking basic questions.
Hi, everything works, colour is perfect, thank you for your patience and help.
