Mug Problems
Re: Mug Problems
you should check your nozzle test :)
quasar
Re: Mug Problems
Post by quasar »
Nozzle check print out looked fine, but I may do a print head clean anyway to see if it improves the situation.
RogerC
Re: Mug Problems
Post by RogerC »
I'm by no stretch of the imagination an 'expert' so take this with a degree of doubt but that looks like a heat mat problem to me......maybe you're clamping the mug too tight?
quasar
Re: Mug Problems
Post by quasar »
Thank you for that, I will check the tension and try again
WorthDoingRight
Re: Mug Problems
Post by WorthDoingRight »
I wonder if you should not try a standard plain paper setting also if none of the above suggestions help. Those white lines can be a product in the past of the following: damp paper or wet ink (let transfer dry a while especially if using a high quality setting), uneven pressure around the mug, not long enough in the press (try 180 for 180), maybe printer banding.
Anyway I hope you fix it soon.
quasar
Re: Mug Problems
Post by quasar »
Thank you . Gradually checking things off the list and trying different things
quasar
Re: Mug Problems
Post by quasar »
Nozzle checked, print head cleaned, pressed lowered slightly, time increased and it is all working really well.
thank you all for your help
WorthDoingRight
Re: Mug Problems
Well thats good news - glad we could all chip in to help.
RogerC
Re: Mug Problems
Post by RogerC »
Good result.......don't you just love this place when the combined advice works.....:biggrin:
Charlie_
Re: Mug Problems
Post by Charlie_ »
RogerC;53830 wrote:Good result.......don't you just love this place when the combined advice works.....:biggrin:
YUp I do .......................................
