Mug Problems
quasar
Re: Mug Problems
Post by quasar »
Hi all,
have a 5 in1 press and have been making t shits for awhile now, but someone gave me an epson SX235W with a set of dye sublimation inks and I decided to try the mug press out.
I am printing from photoshop or silhouette to the epsom, with it set to best photo and photo paper, but when I put the mug in the press and follow the instruction sheet a blank mug comes out. I have checked I am printing on the correct side of the sublimation paper, but just can't work out what I am doing wrong. Any ideas.
Quasar
Re: Mug Problems
are you absolutely sure that the inks in the printer are dye sublimation inks, and not just dye inks?
Also, is the mug you are using a sublimation mug, or just a standard mug?
quasar
Re: Mug Problems
Post by quasar »
The mugs came from BMS, and the inks are CISS/S22 Dye according to the box
Re: Mug Problems
you need sublimation ink. all you have is dye ink. wrong for the job.
quasar
Re: Mug Problems
Post by quasar »
Thank you, thought there may be something wrong.
quasar
Re: Mug Problems
Post by quasar »
checked order code on box and with previous owner, who said ha couldn:t get it to work which is why I got it. Have now contacted original supplier of ink and got the right ink for mug printing, so should be okay soon.
Thanks for the help
Charlie_
Re: Mug Problems
Post by Charlie_ »
Well I use an epson sx435w with great effect I set it to epsom vivid and great colours are coming out..........
CarArtz Dave
Re: Mug Problems
Post by CarArtz Dave »
I did the blank mug thing once (accidentally had normal paper in the printer)
Excitedly peeled back the paper off the mug and...TAADAAAAA!.... nothing :biggrin: lol.
My future Global Empire: www.carartz.com
WorthDoingRight
Re: Mug Problems
Post by WorthDoingRight »
CarArtz Dave;53719 wrote:I did the blank mug thing once (accidentally had normal paper in the printer)
Well that is quite surprising as I have used normal paper before (just to see if sublimation paper was really something special) and always got some image even if a little faded.
quasar
Re: Mug Problems
Post by quasar »
I have the right ink and it is working okay now. Setting printer to best photo quality and photo paper (can't find epsom vivid on mine), have the press at 180 for 120 seconds, but although the image comes out, in places there are stripes instead of full clear colour. Could this mean more time, more heat or should I change to one of the epsom glossy settings?
vB_ID:1190
vB_ID:1190
