Urgent help
NASH
Re: Urgent help
Post by NASH »
Thats strange it opens up on mine okay
AJLA
Re: Urgent help
Post by AJLA »
I've scanned one, downstairs in shop with photoshop, saved it as a jpg, run upstairs loaded it into robo to trace and save as a GSD just drawing it with the pen to see if its ok. I'm running up and down the stairs like a headless chicken, i'll look like an anorexic racing snake at this rate
AJLA
Re: Urgent help
Post by AJLA »
No i've never had this before with the robo nash
AdamB
Re: Urgent help
Post by AdamB »
For a quick fix Mandy, open up an A4 sheet in robo, then click get outline and select the 'image' of the thumb (you'll need to download the image first).
It should then pull up the outlines for you.
Strange how it doesn't work your side though?
AJLA
Re: Urgent help
Post by AJLA »
Yep just done that and it's ok, thankyou very much for such quick replies folks.
Can't understand why it won't open up the GSD i've never seen that message before in the robo
Stitch Up
Re: Urgent help
Post by Stitch Up »
Here's an .eps vector of the jpeg.
thumb.zip
vB_ID:149
(2.06 KiB) Downloaded 17 times
thumb.zip
(2.06 KiB) Downloaded 13 times
AJLA
Re: Urgent help
Post by AJLA »
Thanks Stitch up, i clearly have a problem with my upstairs pc as it won't open that either although this one will so i'll pop it onto a usb and take it up.
