Halogen oven hit & miss results
Pixelpusher
Re: Halogen oven hit & miss results
Post by Pixelpusher »
Hi Guys,
Thought I would give the halogen oven a go, started off with just one mug @ 180c for 10 mins and it came it out great!! then done x2 mugs 180c for 12 mins, both came out very good.
Had another bash yesterday ( a week later) same temp 180c for 12 mins both mugs came out crap very brown, so im guessing burnt and over cooked :(
Very confused :confused: same ink, same paper, same green silicone wraps, also have a stand alone thermometer in the oven so the same temps, done the same thing as the first time waited until temp reached 180c pre-warmed the mugs popped them in the middle of the oven, when timer went off, I took them out and removed the wraps & paper straight away.
Will give it another bash, but is it really this hit & miss using an oven? does a mug press give better results?
Thanks, Mark
Tagging Webtrekker for you as he is the go to guy for halogen ovens.
P.S. Webtrekker, can you recommend a make and approx times/temps as I am half tempted to get one myself.
Pixelpusher
:) Cheers Mate
Hmm... I don't pre-warm mugs when using the oven. Just preheat the oven itself to 180 C (using the thermometer) and bung the mug(s) in. I remove wraps straight away after cooking. I used to dunk them in warm water but there's really no need.
I get consistent results, so I really don't know why yours should be any different. I leave the temperature knob set to the same position all the time, I never alter it. I stand the mugs right-way up. Timing is done with my phone, not the oven timer. I also use the chrome extender ring on the oven to help air circulation.
@SG - I bought my oven from The Transfer Press, but I see they've been out of stock ever since!
Pixelpusher
Webtrekker, thanks for the reply!
I do 100% the same as you, when I say pre-warm the mugs I mean take them out the boxes and let them sitting in the room for a few hours.
Just done another test for the wife, and not very good results once again, colour was supposed to be a hot pink and came out red, the 'this girl' text has a ghost double image above it and the black camping looks very faded.
Need more heat or time or both ? 180c at 10 mins.
vB_ID:5815
vB_ID:5815
vB_ID:5815
vB_ID:5815
vB_ID:5815
vB_ID:5815
vB_ID:5815
vB_ID:5815
vB_ID:5814
vB_ID:5814
vB_ID:5813
vB_ID:5813
vB_ID:5812
vB_ID:5812
I'd say try less time (8 or 9 minutes).
I doubt whether pressing times or temps will improve your colours though. Are you using the recommended ICC profile when printing?
Pixelpusher
webtrekker;139198 wrote:I'd say try less time (8 or 9 minutes).
Oh Ok would less time, take away the fading of the black? Yes im using a recommended ICC for my inks, supplied by Ink Experts.
Maybe its the mugs then giving hit & miss results.
