Photographs of inside of my RICOH SG3110DN - is this normal??
brightday83
Re: Photographs of inside of my RICOH SG3110DN - is this normal??
Post by brightday83 »
Hi,
I bought a printer through someone on the forum about a month back, because the seller said it was in perfect working condition (it cost £90). Yet it has banding issues that I haven't been able to fix, I've tried everything!
Yesterday I lifted the hood off the printer so that I could peer inside, and I spotted these lines (just like the banding that ends up on the prints) running all across a piece of plastic film. Photos attached:
vB_ID:4323
vB_ID:4323
vB_ID:4323
vB_ID:4323
Is this normal? It looks as if the lines are part of the plastic (etched or bumped onto it) rather than ink accumulation.
All replies are appreciated!
vB_ID:4322
vB_ID:4322
brightday83
UK Printed Mugs;117400 wrote:Have a read of this thread in case it helps:
http://www.dyesubforum.co.uk/vbforum/sh ... d-dithered
Thanks, I'll give this a try! :smile:
logobear
Post by logobear »
my belt has lines and works fine
Is it normal for the Ricoh ink lines to have those air bubbles in them?
brightday83
webtrekker;117403 wrote:Is it normal for the Ricoh ink lines to have those air bubbles in them?
I have no idea?! But the worst of the bands are always in one place. I've done a head clean, nozzle check, alignment, head position.
I only ask because air bubbles were the reason I removed the CISS system from my Canon inkjet printer. I've never looked inside my Ricoh's though to see if mine are the same.
brightday83
webtrekker;117406 wrote:I only ask because air bubbles were the reason I removed the CISS system from my Canon inkjet printer. I've never looked inside my Ricoh's though to see if mine are the same.
Did air bubbles cause you banding problems?
They certainly did, but I don't know whether the Ricoh's are any different to a normal CISS system.
Maybe purging your Ricoh would remove the air bubbles and improve the performance banding-wise, but it does take a toll on your ink levels.
