Hi hopefully someone can advise
I have been using the same paper and mugs and inks for over a year recently I have had a few mugs that have what I can only describe as smudges
This is now happening on almost every mug I make
I have bought a new blanket thinking that was the case but it is exact same issue
None of my settings have changed so I am puzzled at what is going wrong
I am trying to upload a pic but struggling
Any advice is greatly appreciated
Help with smudges
Re: Help with smudges
Need to know the following to answer:
Make of Ink
Make of Paper
Make of Press
Where you got the mugs from
What time are you using
What temperature are you using
SG
Make of Ink
Make of Paper
Make of Press
SG
I've returned a batch of mugs with the same problem today, you can have a bad batch of mugs or you need to check the pressure of the blanket and it might correct the uneven surface of the mug.
Thanks both it is one of 3 things, printer, inks or ciss
Printer was under warranty, I have had a few paper feed issues with it so now got a new one which I am setting up. hopefully problem solved
