Help with smudges
canihave
Re: Help with smudges
Post by canihave »
Hi hopefully someone can advise
I have been using the same paper and mugs and inks for over a year recently I have had a few mugs that have what I can only describe as smudges
This is now happening on almost every mug I make
I have bought a new blanket thinking that was the case but it is exact same issue
None of my settings have changed so I am puzzled at what is going wrong
I am trying to upload a pic but struggling
Any advice is greatly appreciated
Need to know the following to answer:
Make of Ink
Make of Paper
Make of Press
Where you got the mugs from
What time are you using
What temperature are you using
SG
Post by GoonerGary »
I've returned a batch of mugs with the same problem today, you can have a bad batch of mugs or you need to check the pressure of the blanket and it might correct the uneven surface of the mug.
canihave
Post by canihave »
Thanks both it is one of 3 things, printer, inks or ciss
Printer was under warranty, I have had a few paper feed issues with it so now got a new one which I am setting up. hopefully problem solved
canihave
Post by canihave »
All sorted it was the printer.
Back in business :)
