cushion covers from transfer press
jennywren
Re: cushion covers from transfer press
Post by jennywren »
I've been looking at these for the last couple of weeks and lack the courage to sublimate on them, can anyone help me, time temp and pressure and so forth. How on earth do I stop the print from going through the bottom layer. Any help would be appreciated as being a bit of coward in trying them which is not like me. I only have 5 and don't really want to ruin them.
dazzul
Post by dazzul »
A tip for stopping the bottom layer could be a sheet of paper inside the case. :) we do that with bottle t shirts. As for pressing i cant help never tried it.
JMugs
Has thanked: 11 times
Been thanked: 10 times
Post by JMugs »
I have a towel folded and pressed (yes in the press) with wallpaper lining paper wrapped around it. This goes inside the cushion cover, then press.
Janners
Benn81
Post by Benn81 »
JMugs;84877 wrote:I have a towel folded and pressed (yes in the press) with wallpaper lining paper wrapped around it. This goes inside the cushion cover, then press.
Janners
I've got to see this, it must be quite thick!?
Do you have photo Janners
Jenny - i do them at 190 - 50 - medium pressure, on adkins press
Benn
JMugs
Post by JMugs »
I can take a photo tomorrow, if you need one. But it is just as described.
Janners.
Benn81
Post by Benn81 »
No, not really Janners,
This must help prevent border lines from the paper when pressed. Good idea
Benn
James990
Post by James990 »
I use an ironing board felt thingy, yep, great with technical words! But got the idea from this wonderful site!
JMugs
Post by JMugs »
Also works inside T- shirts, and I have a long skinny version for the sleeves of hoodies.
Janners
James990
Post by James990 »
We have heard about your long skinny version!
Seriously it is good, when I first tried to print onto Pillow cases and cushion covers, I used a towel inside and it picked up all the ribbing in the towl. Ho hum.
Benn81
Post by Benn81 »
Inventive ideas!, I think i'll give them a go today,
