Yellow Shadow around blacks
Jason
Re: Yellow Shadow around blacks
Post by Jason »
I'm wondering if somebody can shed some light on an intermittent problem I'm getting printing white metal, I'm getting a very slight yellow blurry shadow around some black text, this doesn't appear to be on the actual print, but appears after pressing.
The strange thing is this doesn't appear to affect all of the items, even when they are printed on the same sub sheet, so I'm struggling to understand whats the cause of this.
All help greatly appreciated.
cheers
Jason
Renniwano
Post by Renniwano »
Maybe you could show a pic of an item that's affected.. ??
Has thanked: 11 times
Is the black text 100% black Jason? Is this on a Ricoh?
Jason
Post by Jason »
Sorry I don't have the item here to photograph.
Justin, it's 100% black from RGB colour palette in Coreldraw, printing off the ricoh 5050
Jason
Hi Jason
The fact that it is an intermittent problem suggests to me that it is a temperature issue especially as you are pressing metal as this is probably the only variable factor in the whole process.
Sorry I can not offer advice apart from try dropping the temp and see if that helps at all.
Skye
Post by Skye »
Is black printing using all four colours? & maybe the yellow is sublimating slightly differently.
My Ricoh printer preferences setup has an option to print black from the black cartridge only rather than using CMYK. Try setting the printer to use black only (if it isn't already) to see if it makes a difference.
[ATTACH=CONFIG]2468[/ATTACH]
vB_ID:2468
vB_ID:2468
Jason
Post by Jason »
Thanks Skye I will take a look and give that a try.
