Hi all
In the nearest future i would like to mak emy own phone case print, but i still miss a heat press, sub ink and icc profile. I saw this "member to member" thread and would like to hear if any one can print a pic for me on sublimation heat transfer paper with sublimation ink? i would like to press it self on the 1 phone case i have bought? i would like to see the results before i go ahead with buying the parts
I dont care if the picture is a bit bigger than iphone 4 cover size, its what i am looking for. and i am located in dk. So who are willing to print and send it in a letter? and cost?
thanks in advance
Who can print iphone 4 case sized picture & send it to me?
Re: Who can print iphone 4 case sized picture & send it to me?
I think you will be better off asking for ready printed case. As, no offnce but more likely you will mess your first pressing up
Designandgift
hey gkhnn i think it would be alot cheaper if there was someone on here local to you,
however i would happily print your image and send over, i will make duplicates also just incase you make any errors
i use A4 ricoh gxe3300n printer with sawgrass ink and sawgrass icc, the paper i use is dyesub by magic touch
pm me if interested and i will make sure it is done and posted tomorrow for you
Designandgift
hey paul i was thinking of putting that myself after i pressed send, it would be a better option and make much more sense
If you haven't got a heat press then how are you going to press it?
Using an iron will not work as the temperature needs to be pretty exact and consistent.
if you dont mess up a few times, you never learn anythingPaul;79939 wrote:I think you will be better off asking for ready printed case. As, no offnce but more likely you will mess your first pressing up
socialgiraffe;79945 wrote:If you haven't got a heat press then how are you going to press it?
i have made an temparature controlled unit which can be regulated with a pid controller. I want to use how it will work or not work
