Who can print iphone 4 case sized picture & send it to me?
Gkhnn
Re: Who can print iphone 4 case sized picture & send it to me?
Post by Gkhnn »
Hi all
In the nearest future i would like to mak emy own phone case print, but i still miss a heat press, sub ink and icc profile. I saw this "member to member" thread and would like to hear if any one can print a pic for me on sublimation heat transfer paper with sublimation ink? i would like to press it self on the 1 phone case i have bought? i would like to see the results before i go ahead with buying the parts
I dont care if the picture is a bit bigger than iphone 4 cover size, its what i am looking for. and i am located in dk. So who are willing to print and send it in a letter? and cost?
thanks in advance
I think you will be better off asking for ready printed case. As, no offnce but more likely you will mess your first pressing up ;)
Designandgift
Post by Designandgift »
hey gkhnn i think it would be alot cheaper if there was someone on here local to you,
however i would happily print your image and send over, i will make duplicates also just incase you make any errors
i use A4 ricoh gxe3300n printer with sawgrass ink and sawgrass icc, the paper i use is dyesub by magic touch
pm me if interested and i will make sure it is done and posted tomorrow for you
Designandgift
hey paul i was thinking of putting that myself after i pressed send, it would be a better option and make much more sense
If you haven't got a heat press then how are you going to press it?
Using an iron will not work as the temperature needs to be pretty exact and consistent.
Gkhnn
Post by Gkhnn »
Paul;79939 wrote:I think you will be better off asking for ready printed case. As, no offnce but more likely you will mess your first pressing up ;)
if you dont mess up a few times, you never learn anything :) but thanks for suggestion :)
Gkhnn
Post by Gkhnn »
socialgiraffe;79945 wrote:If you haven't got a heat press then how are you going to press it?
i have made an temparature controlled unit which can be regulated with a pid controller. I want to use how it will work or not work :)
Users browsing this forum: Bing [Bot] and 3 guests
