Layering vinyl for shirts
windyash
Re: Layering vinyl for shirts
Post by windyash »
Hey , ive been doing a few single coloured logos etc on shirts and hoodies and have been asked to do a 3 colour design next , what is the best way to layer this ?
Should I press each colour individually or is there another method so i can do it in one press ?
Mimaki CG60-st cutter , Ricoh 3110 sub printer , OKi laser , Epson inkjet , 2x heat press , mug press , cap press, Flexisign pro and coreldraw X6..............and learning ...........
and now a Roland SP-300v Versacamm !!!!!!
mrs maggot
Post by mrs maggot »
no, you cant do it in i press, depends on who's vinyl you are using, but some press slightly less for layering, best to speak to your supplier, as some colours/vinyls cannot be layerd, so you need to cut clever the design, if you use the "search" function on here you will see more discussions on it
windyash
Post by windyash »
Ok thanks , been using Hotflex from MDP as I use them for sign vinyl ........ will have a search :smile:
spongerobinson
Post by spongerobinson »
We layer hotflex from MDP on a regular basis...haven't had any problems with it. Usually press each layer for about 8 seconds, and then a final press of the lot when finished.
RogerC
Post by RogerC »
If the logo is intricate/small weeding/overlay problems why not go for printed vinyl transfers? Either myself, Socialgiraffe orJason can do these. PM me if I can be of assistance.
windyash
Post by windyash »
Cheers for the replies , will just keep playing then !!!
Thanks RogerC for the offer I will definetly remember for the future !!!!!
