Hey , ive been doing a few single coloured logos etc on shirts and hoodies and have been asked to do a 3 colour design next , what is the best way to layer this ?
Should I press each colour individually or is there another method so i can do it in one press ?
Layering vinyl for shirts
Re: Layering vinyl for shirts
Mimaki CG60-st cutter , Ricoh 3110 sub printer , OKi laser , Epson inkjet , 2x heat press , mug press , cap press, Flexisign pro and coreldraw X6..............and learning ...........
and now a Roland SP-300v Versacamm !!!!!!
- mrs maggot
no, you cant do it in i press, depends on who's vinyl you are using, but some press slightly less for layering, best to speak to your supplier, as some colours/vinyls cannot be layerd, so you need to cut clever the design, if you use the "search" function on here you will see more discussions on it
Ok thanks , been using Hotflex from MDP as I use them for sign vinyl ........ will have a search
spongerobinson
We layer hotflex from MDP on a regular basis...haven't had any problems with it. Usually press each layer for about 8 seconds, and then a final press of the lot when finished.
If the logo is intricate/small weeding/overlay problems why not go for printed vinyl transfers? Either myself, Socialgiraffe orJason can do these. PM me if I can be of assistance.
Cheers for the replies , will just keep playing then !!!
Thanks RogerC for the offer I will definetly remember for the future !!!!!
