Anyone printed any waterproof PU coated hi viz jackets?, got an order for some but not sure what method to use....will be a multi coloured logo, so either dye sub or transfer print with TMT TTC, any advice appreciated
Cheers
PU coated polyester Hi Viz jackets
- DS Designs
Re: PU coated polyester Hi Viz jackets
Yes, and the PU coating melts unless you are very careful! :rolleyes:
[CENTER]
I did some with Siser PU vinyl (full colour print) at 160 degrees with no problems.
I have done Hi Vis with vinyl no problem too..
- DS Designs
Thanks for the replies folks, will get a sample and try it first before I jump in with both feet
Cheers
Cheers
- purpledragon
Ive just printed some pu coated jackets via dye sub i asked advice from my supplier first who said vinyl will work but you would need to dry clean the coats as the lettering my drop off if machine washeded. i have to say though when i dye subbed them they came out great
- DS Designs
Thanks Purpledragon, looks like i'll dyesub them then
cheers
Dave
cheers
Dave
