PU coated polyester Hi Viz jackets
DS Designs
Re: PU coated polyester Hi Viz jackets
Post by DS Designs »
Anyone printed any waterproof PU coated hi viz jackets?, got an order for some but not sure what method to use....will be a multi coloured logo, so either dye sub or transfer print with TMT TTC, any advice appreciated
Cheers
smo
Post by smo »
Yes, and the PU coating melts unless you are very careful! :rolleyes:
[CENTER]
RogerC
Post by RogerC »
I did some with Siser PU vinyl (full colour print) at 160 degrees with no problems.
Renniwano
Post by Renniwano »
I have done Hi Vis with vinyl no problem too..
DS Designs
Thanks for the replies folks, will get a sample and try it first before I jump in with both feet :)
Cheers
purpledragon
Post by purpledragon »
Ive just printed some pu coated jackets via dye sub i asked advice from my supplier first who said vinyl will work but you would need to dry clean the coats as the lettering my drop off if machine washeded. i have to say though when i dye subbed them they came out great
DS Designs
Thanks Purpledragon, looks like i'll dyesub them then :)
cheers
Dave
Users browsing this forum: Amazon [Bot] and 6 guests
