Hi all,
Looking to print a black panel mug, cant be wrong as I only have one.
Went on BMS and the sizes cannot be right?
Panel size
Re: Panel size
The print area on my template is 84mm by 194mm, but if in doubt just measure it.
[ATTACH=CONFIG]1893[/ATTACH]
They can be stunning though.
- vB_ID:1893
- IMG_0062.jpg (80.93 KiB) Viewed 286 times
Re: Panel size
Use a piece of masking tape, Wrap it round the mug and mark off the two edges. Add 2-3mm either side.
Re: Panel size
I think they are fairly straight forward to print. Matching black is hit of a pain to make it look good if that is required. Panel sizes vary from supplier though.
