Seriously thinking of getting a mug press after tonight..
Renniwano
Re: Seriously thinking of getting a mug press after tonight..
Post by Renniwano »
Having one of those days today.. so far have wasted 9 mugs and only printed 24 others..
It's just determined to get me purchasing more hair dye for the grey hair.. but I can have a batch run of 3 mugs at a time.. 2 or 3 times.. and they look great.. next 3 go in (nothing altered.. same as before) and all mugs have issues..
It can be anything from pale areas.. to over cooked areas.. to blooming creased areas.. *which I don't do anything different with my mugs to get the damn creases lol*
So.. even though I have spent out well over £100 on clamps.. and a mug oven.. I am seriously after tonight considering a cheap press to have a bash with..
I can't afford to have that much wastage.. surely a press is going to be less stress!! lmao
Please just someone come along and warrant me spending more money..
logobear
Post by logobear »
any decent sub mug press should be ZERO waste, only human error like putting artwork wonky.
the old fashioned 'clamp' system is flawed IMHO - just get a decent £200 press and use it, keep a spare £50 blanket, coz it will fail (13months?)
we are now doing a run of 120, and will expect zero failure
Ditto what logobear says.
If you are looking for a single unit then Listawoods do a nice one called a Genie. I purchased one for the dinky durhams and latte style mugs and have found it to be a little gem of a machine. If I have a run of 15 or so mugs I will use this machine instead of the 5 at a time press. It produces perfect results everytime.
Have been using it for a couple of months and not had a failure yet.
Stitch Up
Post by Stitch Up »
Buy cheap, buy twice :)
purpledragon
Post by purpledragon »
Stitch Up;75007 wrote:Buy cheap, buy twice :)
... I once bought cheap mug press and seller sent me two!
Both still working very well for us.
Renniwano
Post by Renniwano »
See this is the thing.. I don't like buying cheap as usually buy cheap, buy twice is the case..
BUT I am not in a position at the moment (as usual, comes at the wrong time) to fork out for an expensive press.. I just need something that will do for now while I sort out what I am going to do with this bloody oven and wraps, other than throw it out of the window!!
Hi Renniwano
I have a spare DF50 here that you can borrow until you are ready to purchase. I am in Wisbech so you are only up the road from me. I am in all day everyday (no life me!!!) so you can pop over whenever you want (morning, afternoon or evening).
Blanket is okay and I have never had any problems with it. It sounds like it will be a much better press than what you are currently using and will get your failure rate down to negligible.
Craig from the forum had it on loan for a while and I do not think he had any problems.
PM me if you want any further details/address.
Renniwano
Post by Renniwano »
HUGE thank you to Simon for popping over a press for me to try.. really appreciated and lovely meeting..
This forum really does have some fantastic members :)
AJLA
Post by AJLA »
Hi Renniwano, I had the same problem with creases and a lot of wastage when I first started using my Ricoh, I found that the paper was so saturated it caused this issue. I now leave it to dry for a while and have no wastage. Well apart from the upside down ones:redface:
Very kind of Simon to help you.
Users browsing this forum: Baidu [Spider] and 2 guests
