Hi guys
Take a minute to introduce yourself. We won't bite!
Air MArshall
Re: Hi guys
Post by Air MArshall »
I want to get into the biz of customising shirt and stuff. This is a whole new world to me! I have just purchased a Epson S22 with refillable cartridges and sub inks, I am yet to order a heat press. Been doing vehicle vinyls for about a year now. I haven't even installed the printer yet! No sub paper, I have to import. Scared to print photos with the OEM cartridges as a I have heard that once you install them you cant go back to non-OEM! Anyway, I hope to learn a lot here. Thanks.
Ian M
Re: Hi guys
Post by Ian M »
Welcome to the forum Mos & may I suggest you have a good read of this link which is all about choosing which printer to use for dye sublimation. http://www.dyesubforum.co.uk/vbforum/sh ... ch-Printer
Air MArshall
Re: Hi guys
Thanks man, will do.
Re: Hi guys
Air MArshall;70287 wrote:I want to get into the biz of customising shirt and stuff. This is a whole new world to me! I have just purchased a Epson S22 with refillable cartridges and sub inks,
Hi! welcome on forum. if there is slight chance of posting this back then do it! return it.
more in search bar.
Welcome again :)
Has thanked: 11 times
Re: Hi guys
Hi there and welcome to the forum :-)
DSF Admin
Air MArshall
Re: Hi guys
Paul;70301 wrote:Hi! welcome on forum. if there is slight chance of posting this back then do it! return it.
more in search bar.
Welcome again :)
Will do that sir.
Air MArshall
Re: Hi guys
Ian M;70289 wrote:Welcome to the forum Mos & may I suggest you have a good read of this link which is all about choosing which printer to use for dye sublimation. http://www.dyesubforum.co.uk/vbforum/sh ... ch-Printer
I found it very informative,thank man. A lot of things make sense now!
Re: Hi guys
Welcome along :). Putting OEM inks won't make any difference as you can soon flush these out with just a head clean or two - no problem there.
Air MArshall
Re: Hi guys
@bms, thanks man. So if it does work well with subs I won't have to throw the bl**dy Item away. I thought it had some kind of embedded code to make it stubborn and prevent the interchangeability of OEM and non-OEM carts. If I can swap them around at will, that's cool.
