Hi guys
Air MArshall
Re: Hi guys
I want to get into the biz of customising shirt and stuff. This is a whole new world to me! I have just purchased a Epson S22 with refillable cartridges and sub inks, I am yet to order a heat press. Been doing vehicle vinyls for about a year now. I haven't even installed the printer yet! No sub paper, I have to import. Scared to print photos with the OEM cartridges as a I have heard that once you install them you cant go back to non-OEM! Anyway, I hope to learn a lot here. Thanks.
Re: Hi guys
Welcome to the forum Mos & may I suggest you have a good read of this link which is all about choosing which printer to use for dye sublimation. http://www.dyesubforum.co.uk/vbforum/sh ... ch-Printer
Air MArshall
Re: Hi guys
Hi! welcome on forum. if there is slight chance of posting this back then do it! return it.Air MArshall;70287 wrote:I want to get into the biz of customising shirt and stuff. This is a whole new world to me! I have just purchased a Epson S22 with refillable cartridges and sub inks,
more in search bar.
Welcome again
Air MArshall
Re: Hi guys
Will do that sir.Paul;70301 wrote:Hi! welcome on forum. if there is slight chance of posting this back then do it! return it.
more in search bar.
Welcome again
Air MArshall
Re: Hi guys
I found it very informative,thank man. A lot of things make sense now!Ian M;70289 wrote:Welcome to the forum Mos & may I suggest you have a good read of this link which is all about choosing which printer to use for dye sublimation. http://www.dyesubforum.co.uk/vbforum/sh ... ch-Printer
Re: Hi guys
Welcome along
. Putting OEM inks won't make any difference as you can soon flush these out with just a head clean or two - no problem there.
Air MArshall
Re: Hi guys
@bms, thanks man. So if it does work well with subs I won't have to throw the bl**dy Item away. I thought it had some kind of embedded code to make it stubborn and prevent the interchangeability of OEM and non-OEM carts. If I can swap them around at will, that's cool.
