Qimage Ultimate Help
Any OS, software in here.
meldean
Re: Qimage Ultimate Help
Post by meldean »
Hello.
I have a 14 day trial with qimage ultimate and the only reason why i have downloaded this software is because i have read about it on this forum a few times saying that they print from this software and know that the print quality will be the best everytime.
What i want to know is what are the best settings for this software for sublimation printing?
Do i need to do anything with the images first before i print them to make sure they are the best they can be?
Any help on this software is very much appreciated.
ThankYou
Dean
Hi dean. To get best out of this software you will have to profile your printer via it.
I had a go with qimage and is great sofrware.
meldean
Post by meldean »
Ahh right. So i would need to print the colour charts via qimage and get another profile made up for the software printer combination. So using a profile that was made using photoshop would not give same results.
Well. Profile should work fine. But i would recomend to print charts via software you gping to use....
JSR
Post by JSR »
I use Qimage Studio (the older version).
When printing the charts for Paul to do my profiles, I print his charts through Qimage so that I can store the settings.
When doing a profile through my ColorMunki, you have to use the ColorMunki software - but so long as you remember your settings, you can put them into Qimage when you use the profile later.
Qimage always remembers your settings - including all printer settings - which makes it easier to use than other software that only remembers the layout and not the printer settings.
