[ATTACH=CONFIG]1095[/ATTACH]
hi, my mates dog has had 5 puppies , he wants 5 mugs with a picture of each one and name to give to the buyers as a gift. i have done the pictures but when i print them out they really do just look like a dark blob on paper, is there anyway i could lighten the picture or should i re take the photos with a quality camera. they were taken using a iphone.
any ideas?
picture editing help (photoshop elements)
Dave271069
Re: picture editing help (photoshop elements)
- vB_ID:1095
- Ted dog.jpg (25.76 KiB) Viewed 15 times
Earl Smith
You could try and lighten it in the program but I think you would be better off retaking the photo with the sun behind you or a light shining on the dog. The iphone is good enough.
With any picture, you can not adjust what isn't there. Had a quick look at your image and there is some detail within the image but not much. It is also 72dpi which is very low res. I would suggest you pop back with the quality camera. Iphone is plenty good enough as long as it is set to maximum resolution, but if you have a machine designed to do the job properly then why not use that. Afterall, would you pick up your camera to make a call
Also and just a personal preference, when cutting out an image I always draw round the image and then use feathering to give the edges a slightly softer feel. Not sure if this option is available in Elements but if it is you may want to give it a try.
Good luck
Good luck
Dave271069
PThanks guys. Been messing around with pics I used the brightness and they came out much better. Also I was unsure about feathering as I did not know what it did as I only learnt to cut around the picture today. I've printed my mugs so will try and put a pic up when I get off my phone.
Dave271069
this is what i gave to my mate, he was happy and has just ordered 5 more, COOL!!![ATTACH=CONFIG]1097[/ATTACH]
- vB_ID:1097
- 20120727_102535.jpg (71.16 KiB) Viewed 15 times
