Kindle sleeve
Gelert
Re: Kindle sleeve
Post by Gelert »
I don't have a Kindle and have read the threads discussing the covers only fitting the Kindle Flame etc.
Was just wondering if anyone had bought the kindle sleeves from BMS and if they can confirm that the do indeed fit a UK Kindle and if they could also say which model that would be fab. Got a buyer waiting.
TIA
mrs maggot
Re: Kindle sleeve
Post by mrs maggot »
i would give BMS a ring and ask martin directly
Gelert
Re: Kindle sleeve
Post by Gelert »
Martin's in Turkey:)
I did message BMS yesterday but no response as yet so gave you lot a shout;)
WorthDoingRight
Re: Kindle sleeve
Post by WorthDoingRight »
http://visual.ly/4-generations-kindle-size-comparison
Here is a link to where it shows the actual kindle sizes by model.
BMS says their sleeve has overall dimensions of 120mm x 190mm so would from my calculation be a tight squeeze on the last kindle with keyboard (the grey unit) and generous on the new kindle touch.
Maybe this helps.
Gelert
Re: Kindle sleeve
Post by Gelert »
I got some dimensions off the net yesterday, but it doesn't help too much because the sleeves are a little bit stretchy so may fit when you think they won't.
WorthDoingRight
Re: Kindle sleeve
They will definately fit the kindles that are grey in colour but definately not the old white/cream kindles - so if it is the grey unit or the touch screen one it should fit fine IMHO. Infact I do not think the UK had the old kindles so very likely it would fit any unit purchased in the UK.
Re: Kindle sleeve
Gelert;49956 wrote:Martin's in Turkey:)
i don't have any outstanding pm's but if you've emailed the office then someone should get back unless it's gone directly to spam (unintentionally of course :))
bigj2552
Re: Kindle sleeve
Post by bigj2552 »
bms;49984 wrote:i don't have any outstanding pm's but if you've emailed the office then someone should get back unless it's gone directly to spam (unintentionally of course :))
thought you were off on yer hols martin ??? :confused:
Re: Kindle sleeve
bigj2552;49987 wrote:thought you were off on yer hols martin ??? :confused:
I am! :)...
mrs maggot
Re: Kindle sleeve
nope, clearly says Ferndown, Dorset on your location :wink:
