Sub paper from coralgraph
scottenti
Re: Sub paper from coralgraph
Post by scottenti »
Has anyone purchased any sub paper from coralgraph recently?
I purchased some off them through ebay and the print quality is very poor. I printed pic on new batch of paper and it was very bad quality blurred etc. Then I printed same pic straight after with same settings etc on previous batch of paper and quality was ok must be something wrong with paper I am using correct side of paper.
I have a pack here, never got on with it so I stick to Xpres paper.
i had coralgrah paper before and it was alright. I wouldn't compare it to texprint or truepix but not to bad. Bit dear for what you get tho...
scottenti
Post by scottenti »
The first batch I got was ok But this second batch is useless
JackB
Post by JackB »
scottenti;47143 wrote: I am using correct side of paper.
You should be printing on the brightest side of the paper, if you wet your finger and thumb the sticky side of the paper is the printing side.
Jack.
scottenti
Post by scottenti »
One side is white the other side is off white, I am using the white side
JackB
Post by JackB »
scottenti;47192 wrote:One side is white the other side is off white, I am using the white side
The White side is the right side.
Jack.
JSR
Post by JSR »
I have a pack of it here and would agree with others. It's okay if your intention is to cut every corner imaginable but, otherwise, look to Xpres paper for economy and TruPix/TexPrint for the best. The difference between actual cost-per-sheet is almost negligible.
Users browsing this forum: Amazon [Bot] and 9 guests
