Sub paper from coralgraph
Re: Sub paper from coralgraph
Has anyone purchased any sub paper from coralgraph recently?
I purchased some off them through ebay and the print quality is very poor. I printed pic on new batch of paper and it was very bad quality blurred etc. Then I printed same pic straight after with same settings etc on previous batch of paper and quality was ok must be something wrong with paper I am using correct side of paper.
i had coralgrah paper before and it was alright. I wouldn't compare it to texprint or truepix but not to bad. Bit dear for what you get tho...
You should be printing on the brightest side of the paper, if you wet your finger and thumb the sticky side of the paper is the printing side.scottenti;47143 wrote: I am using correct side of paper.
Jack.
One side is white the other side is off white, I am using the white side
The White side is the right side.scottenti;47192 wrote:One side is white the other side is off white, I am using the white side
Jack.
I have a pack of it here and would agree with others. It's okay if your intention is to cut every corner imaginable but, otherwise, look to Xpres paper for economy and TruPix/TexPrint for the best. The difference between actual cost-per-sheet is almost negligible.
