Hi
We are an engraving business that is expanding into other markets - hence the sublimation forum! I have just bought an Epson S22 but having problems installing the CISS system from Coralgraph.
Everytime i insert the cartridges into the printer and turn it on i keep getting the error unrecognised cartridges.
I understand the Epson S22 isnt a supported printer for sublimation however its the CISS system im having problems with - anyone with help/ideas is much appreciated for a newbie!
I have followed youtube footage but no avail. Im now wondering whether the PCBs are correct?! I have seen a few other comments floating around google about try, try and try again as its common but iv tried since last night
Thanks all
James
www.engravingbd.com
Epson S22 Ciss - HELP PLEASE!!
personalisedbd
Re: Epson S22 Ciss - HELP PLEASE!!
I think good idea is to give Henry from coralgraph a call.
out of interest. is it true that ciss for S22 works with battery to reset the chips??
personalisedbd
Hi Paul,
Thanks for your reply - im guessing Coralgraph only work between mon an fri?
With regards to the battery reset chip i have tried using this several times. I believe the battery is a new thing for the ciss systems. Might try getting another battery.
The one that I've seen does have a little box where you put in the chips from the original cartridges & I pressume there is a battery in there as well. I think you only use the original chips if the printer has run with original cartridges.Paul;33663 wrote:out of interest. is it true that ciss for S22 works with battery to reset the chips??
personalisedbd
The printer i bought was brand new without any cartridges. I was under the impression that the ciss system was to plug into the printer and then add the ink required
Brand new printers come with genuine cartridges ???personalisedbd;33695 wrote:The printer i bought was brand new without any cartridges. I was under the impression that the ciss system was to plug into the printer and then add the ink required
