Lampshades
- Has thanked: 13 times
- Been thanked: 12 times
Re: Lampshades
Had an enquiry to see if I can get photos put onto lampshades. Don't have any more details at this stage but wanted to put the feelers out to see if there's anything available.
This was something I found that made me wonder if anything exists in the subli world....
http://www.glow.co.uk/design-your-own-lampshade.html
Re: Lampshades
I know a supplier that does lamp shades. Very good styles as well and even a wall hanging version, all created for sublimation. Not UK based though. When I get a chance I'll see if I can dig out some images. Was tempted by them myself but not cost effective for what we do.
Re: Lampshades
Nice one Andrew, many thanks
My initial thoughts are that these maybe won't be cost effective because the numbers are likely to be very small but who knows, it's worth a look.
Re: Lampshades
There might be or might be not lamp images appearing on this post. Fingers crossed as never uploaded on here before.
- vB_ID:233
- lamp oblong.jpg (33.88 KiB) Viewed 727 times
- vB_ID:232
- elip lamp1.jpg (6.7 KiB) Viewed 727 times
- vB_ID:231
- elip lamp.jpg (32.26 KiB) Viewed 727 times
- lamp oblong.jpg (34.24 KiB) Viewed 727 times
- elip lamp1.jpg (6.72 KiB) Viewed 727 times
- elip lamp.jpg (32.52 KiB) Viewed 727 times
Re: Lampshades
Panels probably come loose on these so you can print then insert into shade. You can also get spares.
Martin probably has access to these but as already mentioned, volumes possibly aren't worthwhile.
Re: Lampshades
Customer likes the look of these Andrew, any idea where they're from? I don't think the quantities will be high enough to import but may be worth a look
Re: Lampshades
I think they were from Germany Justin. I'll have to check. I had an order in from them just before this thread was started. If I am going to get more stuff soon I will let you know.
