Lampshades
Help in finding new products.
Has thanked: 13 times
Been thanked: 12 times
Re: Lampshades
Had an enquiry to see if I can get photos put onto lampshades. Don't have any more details at this stage but wanted to put the feelers out to see if there's anything available.
This was something I found that made me wonder if anything exists in the subli world....
http://www.glow.co.uk/design-your-own-lampshade.html
Andrew
Re: Lampshades
Post by Andrew »
I know a supplier that does lamp shades. Very good styles as well and even a wall hanging version, all created for sublimation. Not UK based though. When I get a chance I'll see if I can dig out some images. Was tempted by them myself but not cost effective for what we do.
Re: Lampshades
Nice one Andrew, many thanks :-) My initial thoughts are that these maybe won't be cost effective because the numbers are likely to be very small but who knows, it's worth a look.
jennywren
Re: Lampshades
Post by jennywren »
I rally like the look of them, they are different
Andrew
Re: Lampshades
Post by Andrew »
There might be or might be not lamp images appearing on this post. Fingers crossed as never uploaded on here before.
vB_ID:233
vB_ID:233
lamp oblong.jpg (33.88 KiB) Viewed 730 times
vB_ID:232
vB_ID:232
elip lamp1.jpg (6.7 KiB) Viewed 730 times
vB_ID:231
vB_ID:231
elip lamp.jpg (32.26 KiB) Viewed 730 times
lamp oblong.jpg (34.24 KiB) Viewed 730 times
elip lamp1.jpg (6.72 KiB) Viewed 730 times
elip lamp.jpg (32.52 KiB) Viewed 730 times
Andrew
Re: Lampshades
Post by Andrew »
Panels probably come loose on these so you can print then insert into shade. You can also get spares.
Martin probably has access to these but as already mentioned, volumes possibly aren't worthwhile.
Re: Lampshades
Look very interesting, be good to find a supplier.
Re: Lampshades
Customer likes the look of these Andrew, any idea where they're from? I don't think the quantities will be high enough to import but may be worth a look :-)
Andrew
Re: Lampshades
Post by Andrew »
I think they were from Germany Justin. I'll have to check. I had an order in from them just before this thread was started. If I am going to get more stuff soon I will let you know.
Re: Lampshades
Nice one :-) Could just do with a couple to play with really...to start :-)
