Cork Backing On Coasters Bubbling
r2uzenblot
Re: Cork Backing On Coasters Bubbling
Post by r2uzenblot »
I'm finding that on some of my cork backed coasters the cork bubbles up after pressing. Pressing is 180c for 70 seconds. Should I drop the time down?
pcwizme
Post by pcwizme »
I expect alas this is due to the quality of the coaster not the method, Are these from a reputable supplier?
r2uzenblot
pcwizme;152491 wrote:I expect alas this is due to the quality of the coaster not the method, Are these from a reputable supplier?
Yes from one of (I think) the leading two suppliers who exhibit at the big trade shows.
Mrteajunkie
Has thanked: 6 times
Been thanked: 4 times
Post by Mrteajunkie »
Are you pressing the print side up?
obviously heating the cork directly will cause issues.
r2uzenblot
Mrteajunkie;152495 wrote:Are you pressing the print side up?
Yes print side up
Mrteajunkie
I would certainly give the suppliers a call.
It is moisture. You need to pre-press upside down for 30 seconds then press the right way up.
