Cork Backing On Coasters Bubbling
r2uzenblot
Re: Cork Backing On Coasters Bubbling
I'm finding that on some of my cork backed coasters the cork bubbles up after pressing. Pressing is 180c for 70 seconds. Should I drop the time down?
I expect alas this is due to the quality of the coaster not the method, Are these from a reputable supplier?
r2uzenblot
Yes from one of (I think) the leading two suppliers who exhibit at the big trade shows.pcwizme;152491 wrote:I expect alas this is due to the quality of the coaster not the method, Are these from a reputable supplier?
- Mrteajunkie
- Has thanked: 6 times
- Been thanked: 3 times
Are you pressing the print side up?
obviously heating the cork directly will cause issues.
r2uzenblot
Yes print side upMrteajunkie;152495 wrote:Are you pressing the print side up?
- Mrteajunkie
- UK Printed Mugs
It is moisture. You need to pre-press upside down for 30 seconds then press the right way up.
