*new to sublimation* Hardboard coaster problems
Lee_2023
Re: *new to sublimation* Hardboard coaster problems
Post by Lee_2023 »
Hi I’m new to sublimation. It’s my first week using my setup (epson sc-f500 and galaxy swing press). Lots of hiccups, but most I think are teething problems and getting used to the equipment and experimenting.
However I seem to be having a major issue with hardboard coasters. The tops are peeling off, splitting and lifting. I have pressed the coasters with the sublimation paper and artwork to the top of the press and every coaster I have done results in some form of lifting despite using suppliers recommended heat temps, times and pressures.
what could be causing this? I’m out of ideas to try. 😞. Many thanks in advanced.
[ATTACH=CONFIG]7124[/ATTACH]
[ATTACH=CONFIG]7123[/ATTACH]
[ATTACH=CONFIG]7122[/ATTACH]
vB_ID:7124
vB_ID:7124
vB_ID:7123
vB_ID:7123
vB_ID:7122
vB_ID:7122
Terrible coasters are your problem. Grab some unisub ones and do at 180c for 85s.
Orangeoctopus
Post by Orangeoctopus »
I've given up on MDF coasters due to warping, now switched to aluminium coasters
23express
Post by 23express »
Hi Paul,
Where can I find the aluminium coasters you are talking about? Do you have any links please?
Adam
Sent from my SM-G991B using Tapatalk
