Hi,
I was wondering if anyone is selling any spare parts for the ST-3042.
My machine keeps shorting when I open the lid. I think the wiring is shot and needs to be replaced.
It heats up fine (both plates) vacuum works as well as the timmer.
But if you move the lid, sometime, it shorts the whole house.
Any helps, recommendations, ideas, or do you know someone who could look at it please, I would be very grateful.
I am based in leicestershire.
Thank you
Rich
Wanted: ST-3042 spare parts
Re: Wanted: ST-3042 spare parts
My kettle does that sometimes, usually because there is moisture in the base. Have you checked that your problem isn't as simple as a bit of damp in the mechanism or the plug?
Seach on ebay for faulty machine or FacebookBigSmoke;150849 wrote:Hi,
seach on ebay for faulty machines .
Thank you
Rich
Have you emptied the part at the back under the casing which collects the moisture pulled through in the vacuum?pw66;150850 wrote:My kettle does that sometimes, usually because there is moisture in the base. Have you checked that your problem isn't as simple as a bit of damp in the mechanism or the plug?
Sent from my SM-G781B using Tapatalk
