Uneven dye transfers on hard surfaces (ceramic plates)
vulture_culture
Re: Uneven dye transfers on hard surfaces (ceramic plates)
Post by vulture_culture »
Hello I am new to sublimating, but I have been trying to sublimate onto vintsge ceramic plates.
I have primed my plates using Subliglaze Adhesion Promoter, and Subliglaze Clear Sublimation Coating spray with multiple coats, and allowed the plates to cure for the appropriate time and temperature in a small convection oven.
I am using A-Sub sublimation paper (125 G, 8.5x11) and printing on the paper with an Epson 2720 using Hiipoo sublimation ink.
The heat press I am using just says it is a Combination Heat Press Machine.
When I heat press I allow the heat press to heat up to 400 degrees F. Then I pre-heat the plates before sublimating by heat pressing onto the plate for about 5-10 seconds. I found some advice that said that pre-heating the surface will allow the ink to transfer more evenly.
Then I sublimate the plates. I've tried 240sec (the hippo), 220sec, 200sec (the leopard), 180 sec(giraffe), 160sec (the heart). I've had the best results with 180 seconds (the giraffe).
However, most of the plates have a small depression in the middle of the plate, directly in the center. It looks like most of my plates are blurry in the very center of the plate where the depression is. Moreover, most of my plates are not transferring very well at the very edges of the image I am trying to sublimate.
Thanks for your help!
[ATTACH=CONFIG]6731[/ATTACH][ATTACH=CONFIG]6734[/ATTACH][ATTACH=CONFIG]6733[/ATTACH][ATTACH=CONFIG]6732[/ATTACH][ATTACH=CONFIG]6730[/ATTACH][ATTACH=CONFIG]6735[/ATTACH]
vB_ID:6735
vB_ID:6735
vB_ID:6730
vB_ID:6730
vB_ID:6732
vB_ID:6732
Giraffe 2.jpg (93.79 KiB) Viewed 292 times
vB_ID:6733
vB_ID:6733
leopard 1.jpg (76.84 KiB) Viewed 292 times
vB_ID:6734
vB_ID:6734
leopard 2.jpg (79.7 KiB) Viewed 292 times
vB_ID:6731
vB_ID:6731
Giraffe 1.jpg (79.46 KiB) Viewed 292 times
If there is a small depression in the middle of your plates I would that your flat heat press platen isn't making full contact which would cause this.
I assume you're using a plate press platen?
It's not normally necessary to pre heat anything unless it has possible moisture. Have you tried without? Unless this is specific to your coating which I wouldn't know.
vulture_culture
Thanks, yes it is with a plate press platen. I have tried sublimation without pre-heating the plates, but I had worse results.
Is there a technique you know of that would allow me to get full contact with a plate press platen if the plates have a small depression in the center of the plates? I've seen some people put rubber silicon baking sheets between the plate press platen and the plates, but I am not sure if that will solve my problem.
I've done similar on mug bases that were slightly concave, adding small pieces of rubber sheet. Problem is you have to up the temp and/or time and the rest of the image may suffer as a result.
My immediate thoughts are that you need to be using perfectcly flat plates but maybe someone else can offer a solution.
They 'may' work with shrink in an oven as this take up all uneveness.
rgsearley
Post by rgsearley »
I use a bit of 1mm silicone sheet it helps with the uneven surface of the plate also gives slightly more even heat distribution
But I have to add about 90 seconds to the time
Sent from my SM-F916B using Tapatalk
