Longer/shorter time or higher/lower heat?
Re: Longer/shorter time or higher/lower heat?
I've often wondered if when sublimating an item - let's say a mug for this example - what is the more important thing to prioritise (once you get past a minimum sublimation temperature of course); time of pressing, or temperature? So long as an item reaches the required temperature for actual sublimation to occur, does it matter if it's cooked for a longer time at a lower temperature or a lower temperature for a longer time?
Both time and temp are critical. However, depedning on your press/oven sometimes you can cook at a lower temp. for a longer time as we do in our oven.
Leaving an item for longer than required doesn't usually matter to a point, after thenm it can start to brown/burn the paper which could affect the print and cause blurring.
Many years ago I had a chat with with the folks at Chromaluxe and they liked longer at lower as it gave greater penetration and hence longevity of the print. Allegedly.
Janners
Janners
Users browsing this forum: Bing [Bot] and 2 guests
