Is it possible to sublimate coasters or flat objects in an oven?
Or do you need a heatpress?
Coasters in ovem
- Mrteajunkie
- Has thanked: 5 times
- Been thanked: 3 times
Re: Coasters in ovem
I wouldn’t try it myself.
you need the pressure on the paper to transfer the image but I may be wrong as I have never tried it.
Only in a 3D vacuum press oven I would guess. But why bother when flat heat presses are cheap and work perfectly? Ready in 60 seconds!
You could probably use heat shrink, but like others have said, why bother when a cheap heat press will do the job easier and quicker...
Thanks everyone
I was just thinking of space and what equipment I need .
Thanks again
Thanks again
