Coasters in ovem
Robbiejd
Re: Coasters in ovem
Post by Robbiejd »
Is it possible to sublimate coasters or flat objects in an oven?
Or do you need a heatpress?
Mrteajunkie
Has thanked: 6 times
Been thanked: 3 times
Post by Mrteajunkie »
I wouldn’t try it myself.
you need the pressure on the paper to transfer the image but I may be wrong as I have never tried it.
Post by GoonerGary »
Only in a 3D vacuum press oven I would guess. But why bother when flat heat presses are cheap and work perfectly? Ready in 60 seconds!
You could probably use heat shrink, but like others have said, why bother when a cheap heat press will do the job easier and quicker...
Robbiejd
Post by Robbiejd »
Thanks everyone
I was just thinking of space and what equipment I need .
Thanks again
They will warp.
They will warp.
Good point :-)
Users browsing this forum: No registered users and 14 guests
