https://youtu.be/bbV64msy4KE
P.S. If you do not know what you are watching then it's probably not for you...
Nope...JMugs;146275 wrote:Ohhh shiny toy with ink and slidy thing.....
I have one of those but not borderless.socialgiraffe;146277 wrote:Nope...
You can get borderless on yours as well. I will be sharing once I have written clear instructions...I have one of those but not borderless.
what’s the trick then are you going to share?
You certainly know how to keep us in suspense!!!
Go on, spill the beans.
If you want to get ahead and prepare then I suggest you order some paper from INK EXPERTS or LISTAWOOD (if you use TRUPIX) as I know that both of these companies will trim the paper to your measurements for you. I am sure there are others that also offer the same service.Yes, I’ve discovered the joys of trimming mug paper
