If you know... you know...
Re: If you know... you know...
I have been working on this for a couple of weeks now. Its probably the best gift I can give myself this year :-)
https://youtu.be/bbV64msy4KE
P.S. If you do not know what you are watching then it's probably not for you...
JMugs
Has thanked: 10 times
Been thanked: 10 times
Post by JMugs »
Ohhh shiny toy with ink and slidy thing.....
JMugs;146275 wrote:Ohhh shiny toy with ink and slidy thing.....
Nope...
Mrteajunkie
Has thanked: 5 times
Been thanked: 3 times
Post by Mrteajunkie »
socialgiraffe;146277 wrote:Nope...
I have one of those but not borderless.
what’s the trick then are you going to share?
You can get borderless on yours as well. I will be sharing once I have written clear instructions...
cjh67
Post by cjh67 »
You certainly know how to keep us in suspense!!!
Go on, spill the beans.
ha ha, sorry I had completely forgotten about this, give me a few days and I will sort out the settings and how it can be done etc.
It really has made such a huge difference to me as I will never have to cut down mug paper again.
P.S. Sorry for adding yet more suspense, I am just a bit busy at the mo.
cjh67
Post by cjh67 »
Yes, I’ve discovered the joys of trimming mug paper :(
Be good to know how you did it.
Thank you :)
Regards
CJ
If you want to get ahead and prepare then I suggest you order some paper from INK EXPERTS or LISTAWOOD (if you use TRUPIX) as I know that both of these companies will trim the paper to your measurements for you. I am sure there are others that also offer the same service.
I have my paper trimmed to 239mm x 92mm so it is the exact height of the mug and the exact circumference up to the handle. Obviously these measurements will change according to your requirements, particularly if you use 11oz mugs. The bottom line is that you just need the paper trimmed to the height of your mugs, the circumference is not as important in my opinion.
cjh67
Post by cjh67 »
I bought 300 sheets of the inkexperts mug paper just before Christmas - 210 x 99 I think - it is a tad oversize height wise but I have an accurate trimmer here.
It would be so good to be able to line up nicely and still achieve full coverage!
I have a 3110 so your fix may not work for me but here’s hoping.
Regards
CJ
