Paper/Heat Element leaving imprint film on mug
Claire-Thistledown
Re: Paper/Heat Element leaving imprint film on mug
Post by Claire-Thistledown »
Hi - I have previously used BMS balmoral mugs with Ink Experts paper and heated to 180d for 100secs. (Apologies for my non technical lingo) I have never had an issue with this. Due to the shortages, I have now purchased Balmoral mugs through Coral. I am now getting a print mark of where my paper has been wrapped around the mug with the pattern of the heat element wrap on that area? I have tried adjusting my time and temp, but nothing i do is making a difference! help please! Many thanks in advance. Image attached.
[ATTACH=CONFIG]6435[/ATTACH]
vB_ID:6435
vB_ID:6435
WhatsApp Image 2020-11-17 at 15.03.10 (2).jpg (21.51 KiB) Viewed 13 times
Claire-Thistledown
Heat blanket i mean not element :rolleyes:
Mrteajunkie
Has thanked: 5 times
Been thanked: 3 times
Post by Mrteajunkie »
Are you printing on the right side of the paper?
Claire-Thistledown
Mrteajunkie;145669 wrote:Are you printing on the right side of the paper?
Yep, defo the right side of the paper. Its printed on the wrong side so I can't get that wrong!
Post by GoonerGary »
Well I can see that your printed image is blurred. Try reducing the temperature by 10 degrees C along with a matching time to get a sharp print and see if the other problem goes too.
0202
Post by 0202 »
Claire-Thistledown;145664 wrote:Hi - I have previously used BMS balmoral mugs with Ink Experts paper and heated to 180d for 100secs. (Apologies for my non technical lingo) I have never had an issue with this. Due to the shortages, I have now purchased Balmoral mugs through Coral. I am now getting a print mark of where my paper has been wrapped around the mug with the pattern of the heat element wrap on that area? I have tried adjusting my time and temp, but nothing i do is making a difference! help please! Many thanks in advance. Image attached.
Hi, I know this post is old but just wondered did you manage to find a solution? I have just got some new mugs and have the same type marks from the paper and heat blanket. Thank you
