Nigel Gray
Take a minute to introduce yourself. We won't bite!
n gray
Re: Nigel Gray
Post by n gray »
Hi all , new member here hu3 4hh , we have been Dye subbing for a couple of years now on all over on a4 size panels quite succesfully , we have moved to a3 size panels and are getting a unprinted dot in the centre of the heat press
Any ideas or recommendations on a good quality a3 + sized heat press ??
Thanks in advance :)
Nigel
Andrew
Re: Nigel Gray
Post by Andrew »
What type of panels are you printing? Wood / metal?
Adkins was the best press I had. George Knight second best. Rigid A3 items are quite hard to print and and bit of a goldilocks item where everything has to be just right. We often print 2 A4 sizes in one go easily but if they were one complete A3 it can easily go wrong. If you are going to be doing them regularly you are best trying to keep a dedicated press so settings don't change.
Never used pneumatic press but that would depend on your budget.
n gray
Re: Nigel Gray
Post by n gray »
Hi Andrew thanks for the reply , we are printing onto plastic , i will have to have a play around with the settings .
Andrew
Re: Nigel Gray
Post by Andrew »
A bit of padding out on the base can help which allows for some self levelling. Depends on your press really.
Re: Nigel Gray
Personally our preference for presses are PressMech, and have printed full size metal and acrylics sheets in them fine.
n gray
Re: Nigel Gray
Post by n gray »
What thikness acrylic did you sub onto ???
Re: Nigel Gray
Hi Nigel and welcome to the forum.
DSF Admin
JMugs
Has thanked: 10 times
Been thanked: 10 times
Re: Nigel Gray
Post by JMugs »
I have a Pressmech A2 press and a Pressmech bag press which does up to A3+.....can you guess who I would recommend....:biggrin:
Janners
Re: Nigel Gray
... adding to JMugs' post - we have 5 A3+ PressMechs!
In terms of thickness of acrylic, I think it was 5mm that we did for a few projects some years ago.
For aluminium, we do from .5mm up to 1.1mm
n gray
Re: Nigel Gray
Post by n gray »
Hi thanks for that we have been playing with 3mm acrylic and getting reasonable results
