Does anyone here print business cards or leaflets?
Mrteajunkie
Has thanked: 6 times
Been thanked: 4 times
Re: Does anyone here print business cards or leaflets?
Post by Mrteajunkie »
I’m looking for some cards or leaflets for my eBay sales.
the usual thank you for your purchase with contact info and a little polite feedback request.
im currently printing 2 on an a4 sheet and cutting in half but would like something a little more professional.
If possible a price for 1000 please.
Cheap enough on eBay but I would rather give someone here the business.
TIA
paul.
Brant
Post by Brant »
Hi Mr Tea - I print Flyers but I'm based in Worcester and the postage would probably not make it cost effective for you to use me. Unless anyone in the Forum is closer to you I would recommend Route One Print or Solopress.
Baldy
Post by Baldy »
We sell leaflets and business cards if you're still looking. I can do you:
1000 x A5 double-sided on 150gsm silk - £32 delivered
Other stocks available
Mrteajunkie
Baldy;141907 wrote:We sell leaflets and business cards if you're still looking. I can do you:
Sounds good.
Can i send you a word doc with what im currently using?
Baldy
Post by Baldy »
I'm afraid we can't work with Word/Publisher files (even pc to pc, the results/layout can be very different), instead accepting pdf and jpg at the specs below:
Colour Mode: CMYK
Resolution: 300dpi
Bleed: 3mm each edge
Safe area 3mm from trim line
Full specs can be viewed here and I have a layout template I can always send you if you like, containing all the bleed/safe area guides.
