I’m looking for some cards or leaflets for my eBay sales.
the usual thank you for your purchase with contact info and a little polite feedback request.
im currently printing 2 on an a4 sheet and cutting in half but would like something a little more professional.
If possible a price for 1000 please.
Cheap enough on eBay but I would rather give someone here the business.
TIA
paul.
Does anyone here print business cards or leaflets?
- Mrteajunkie
- Has thanked: 6 times
- Been thanked: 4 times
Re: Does anyone here print business cards or leaflets?
Hi Mr Tea - I print Flyers but I'm based in Worcester and the postage would probably not make it cost effective for you to use me. Unless anyone in the Forum is closer to you I would recommend Route One Print or Solopress.
We sell leaflets and business cards if you're still looking. I can do you:
1000 x A5 double-sided on 150gsm silk - £32 delivered
Other stocks available
- Mrteajunkie
Sounds good.Baldy;141907 wrote:We sell leaflets and business cards if you're still looking. I can do you:
Can i send you a word doc with what im currently using?
I'm afraid we can't work with Word/Publisher files (even pc to pc, the results/layout can be very different), instead accepting pdf and jpg at the specs below:
Colour Mode: CMYK
Resolution: 300dpi
Bleed: 3mm each edge
Safe area 3mm from trim line
Full specs can be viewed here and I have a layout template I can always send you if you like, containing all the bleed/safe area guides.
Colour Mode: CMYK
Resolution: 300dpi
