I have a lot of mug oven wraps that use the Red Silicone rubber which have torn and wonder if anyone knows if it is possible to get replacement sheets of this material to replace them?
Many Thanks
Replacement rubber for Heat Wraps
Re: Replacement rubber for Heat Wraps
I've had a go at making my own using a similar silicon material. You can find different thickness sheets on eBay. It's fixing it the clamps that could be tricky.
Thanks Justin, Just found a 1mm thick sheet from China and will give it a try. The clamps are tricky but found that my existing ones did move a bit so used to fixing them.
