Replacement rubber for Heat Wraps
johna1954
Re: Replacement rubber for Heat Wraps
Post by johna1954 »
I have a lot of mug oven wraps that use the Red Silicone rubber which have torn and wonder if anyone knows if it is possible to get replacement sheets of this material to replace them?
Many Thanks
I've had a go at making my own using a similar silicon material. You can find different thickness sheets on eBay. It's fixing it the clamps that could be tricky.
johna1954
Post by johna1954 »
Thanks Justin, Just found a 1mm thick sheet from China and will give it a try. The clamps are tricky but found that my existing ones did move a bit so used to fixing them.
